BTT window snapping doesn't work. I've tried reinstalling the app and confirmed that Window Snapping is enabled. Just not sure what else to try.
In general make sure that BTT has the permissions in System Preferences => Security & Privacy => Privacy => Accessibility. If it is already added there, maybe try to delete it and add it again.
It was in there, but removing it seems to have fixed it, thanks. Just FYI, doing that actually completely blocks input of any kind, so I had to hard-reset my laptop to get BTT to release input back to the OS.
Same issue, since I purchased a licensed two weeks ago, the tool doesn't work and I am unable to use window snapping which is the only reason why I purchased the license. Before that I used bettertouchtool for years (for free) and it worked without a problem. How do I get this working?
At least one of the edges must be enabled (top, left or right) for the corners to work. Snap to top left, top right, bottom left, bottom right do not work on their own.
