I am noticing a bit elevated CPU usage from BTT.
Open files:
/Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool
/System/Library/Frameworks/CFNetwork.framework/Versions/A/Resources/Localizable.loctable
/System/Library/CoreServices/SystemVersion.bundle/English.lproj/SystemVersion.strings
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/SystemAppearance.car
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/FauxVibrantDark.car
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/InputManager.loctable
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/DictationManager.loctable
/private/var/db/analyticsd/events.allowlist
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/MenuCommands.loctable
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/Document.loctable
/usr/lib/libobjc-trampolines.dylib
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/Common.loctable
/System/Library/Caches/com.apple.IntlDataCache.le.kbdx
/System/Library/Keyboard Layouts/AppleKeyboardLayouts.bundle/Contents/Resources/InfoPlist.loctable
/System/Library/Input Methods/TCIM.app/Contents/PlugIns/TCIM_Extension.appex/Contents/Resources/InfoPlist.loctable
/System/Library/CoreServices/System Events.app/Contents/Resources/InfoPlist.loctable
/Applications/BetterTouchTool.app/Contents/Resources/Assets.car
/Users/my-user-name/Library/Application Support/BetterTouchTool/btt_data_store.version_4_271_build_42712-shm
/System/Volumes/Preboot/Cryptexes/App/System/Applications/Safari.app/Contents/Resources/en.lproj/InfoPlist.strings
/Applications/BetterTouchTool.app/Contents/Frameworks/MIKMIDI.framework/Versions/A/MIKMIDI
/Applications/BetterTouchTool.app/Contents/Frameworks/LetsMove.framework/Versions/A/LetsMove
/Applications/BetterTouchTool.app/Contents/Frameworks/BTTPluginSupport.framework/Versions/A/BTTPluginSupport
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/NSColorPanel.loctable
/Applications/BetterTouchTool.app/Contents/Frameworks/ShortcutRecorder.framework/Versions/A/ShortcutRecorder
/Applications/BetterTouchTool.app/Contents/Frameworks/Ensembles.framework/Versions/A/Ensembles
/Library/Preferences/Logging/.plist-cache.vT2yP0uN
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/ControlStripAppearance.car
/Applications/BetterTouchTool.app/Contents/Frameworks/Sparkle.framework/Versions/B/Sparkle
/usr/share/icu/icudt72l.dat
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/DarkAqua.car
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/VibrantDark.car
/private/var/db/mds/messages/501/se_SecurityMessages
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/FauxVibrantLight.car
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/VibrantLight.car
/Applications/BetterTouchTool.app/Contents/Resources/BTT-icon6.tiff
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/NSColorPanelExtras.loctable
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/NSColorPickerSliders.loctable
/Applications/BetterTouchTool.app/Contents/Resources/BTTFloatingHTML.storyboardc/NSWindowController-xze-ZD-QQU.nib
/System/Library/PrivateFrameworks/MarkupUI.framework/PlugIns/Markup.appex/Contents/Resources/InfoPlist.loctable
/System/Library/PrivateFrameworks/SFSymbols.framework/Versions/A/Resources/CoreGlyphs.bundle/Contents/Resources/Assets.car
/System/Library/Fonts/SFNS.ttf
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/Aqua.car
/System/Library/Fonts/Helvetica.ttc
/System/Library/Keyboard Layouts/AppleKeyboardLayouts.bundle/Contents/Resources/AppleKeyboardLayouts-L.dat
/System/Library/Extensions/IOHIDFamily.kext/Contents/PlugIns/IOHIDLib.plugin/Contents/MacOS/IOHIDLib
/System/Library/Frameworks/Foundation.framework/Versions/C/Resources/FoundationErrors.loctable
/System/Volumes/Preboot/Cryptexes/App/System/Applications/Safari.app/Contents/Resources/en.lproj/ServicesMenu.strings
/System/Library/Fonts/LastResort.otf
/System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
/System/Library/Frameworks/FileProvider.framework/OverrideBundles/iCloudDriveFileProviderOverride.bundle/Contents/MacOS/iCloudDriveFileProviderOverride
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/FunctionRowAppearance.car
/System/Library/Frameworks/Security.framework/Versions/A/PlugIns/csparser.bundle/Contents/MacOS/csparser
/System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
/private/var/folders/6x/y97363x167qb9kccbvwv237r0000gn/C/com.apple.WebPrivacy/QUERY_PARAM.wplist
/System/Library/CoreServices/Finder.app/Contents/Resources/InfoPlist.loctable
/System/Volumes/Preboot/Cryptexes/OS/System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Resources/en.lproj/Localizable.stringsdict
/private/var/folders/6x/y97363x167qb9kccbvwv237r0000gn/C/com.apple.scriptmanager2.le.cache
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/Base.lproj/NSTextTouchBarItems.nib
/private/var/folders/6x/y97363x167qb9kccbvwv237r0000gn/C/com.apple.WebPrivacy/ALLOWED_QUERY_PARAM.wplist
/System/Library/Input Methods/EmojiFunctionRowIM.app/Contents/PlugIns/EmojiFunctionRowIM_Extension.appex/Contents/Resources/InfoPlist.loctable
/System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/Resources/DesignLibrary-macOS.bundle/Contents/Resources/macOSRepositories/DarkStandard.car
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/NSAppearanceNameCandidateBar.car
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/TextTouchBar.loctable
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/Services.loctable
/System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/Resources/DesignLibrary-macOS.bundle/Contents/Resources/macOSRepositories/LightStandard.car
/System/Library/PrivateFrameworks/ShareKit.framework/Versions/A/Resources/ShareKit.loctable
/System/Library/Frameworks/CoreImage.framework/Versions/A/Resources/Filters.loctable
/System/Library/Frameworks/CoreImage.framework/Versions/A/Resources/Keys.loctable
/System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/AMDRadeonX6000GLDriver
/private/var/folders/6x/y97363x167qb9kccbvwv237r0000gn/C/com.hegenberg.BetterTouchTool/com.apple.metal/32023/libraries.data
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/Assets.car
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/Assets.car
/System/Library/Fonts/SFCompact.ttf
/private/var/folders/6x/y97363x167qb9kccbvwv237r0000gn/C/com.hegenberg.BetterTouchTool/com.apple.metal/16777237_9765376/functions.data
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/Placeholders.loctable
/Users/my-user-name/Library/HTTPStorages/com.hegenberg.BetterTouchTool/httpstorages.sqlite-shm
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/NSTouchBarReducedMetricsAppearance.car
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/TouchBar.loctable
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/NSTextTouchBarItems.loctable
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/DarkGraphite.car
/private/var/db/nsurlstoraged/dafsaData.bin
/System/Library/Fonts/PingFang.ttc
/private/var/folders/6x/y97363x167qb9kccbvwv237r0000gn/0/com.apple.LaunchServices.dv/com.apple.LaunchServices-5019-v2.csstore
/System/Library/Frameworks/CoreImage.framework/Versions/A/Resources/Descriptions.loctable
/System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/Resources/tokruleLE.data
/System/Library/LinguisticData/Latn/Dict2.dat
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/Menus.loctable
/System/Library/LinguisticData/Latn/Dict1.dat
/System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/Resources/com.apple.datadetectorscore.cache.urlifier.system
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/Accessibility.loctable
/System/Library/Frameworks/AppKit.framework/Versions/C/Resources/AccessibilityImageDescriptions.loctable
/System/Library/Fonts/Keyboard.ttf
/System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
/usr/share/langid/langid.inv
/System/Library/Fonts/Apple Color Emoji.ttc
/dev/null
/dev/null
/dev/null
/Users/my-user-name/Library/Application Support/BetterTouchTool/Logs/com.hegenberg.BetterTouchTool 2023-10-22--06-55-03-711.log
/Users/my-user-name/Library/Application Support/BetterTouchTool/btt_data_store.version_4_271_build_42712-wal
->0xe0a01b208e3e204b
/Users/my-user-name/Library/HTTPStorages/com.hegenberg.BetterTouchTool/httpstorages.sqlite-wal
->0xe0a01b208e3e3fe3
/System/Library/Frameworks/CoreImage.framework/Versions/A/Resources/ci_stdlib.metallib
/System/Library/Frameworks/CoreImage.framework/Versions/A/Resources/ci_filters.metallib
/System/Library/Frameworks/CoreImage.framework/Versions/A/Resources/ci_stdlib_stitchable.metallib
/System/Library/Frameworks/CoreImage.framework/Versions/A/Resources/ci_filters_stitchable.metallib
/System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSImage.framework/Versions/A/Resources/default.metallib
/private/var/folders/6x/y97363x167qb9kccbvwv237r0000gn/C/com.hegenberg.BetterTouchTool/com.apple.metal/32023/libraries.list
/private/var/folders/6x/y97363x167qb9kccbvwv237r0000gn/C/com.hegenberg.BetterTouchTool/com.apple.metal/16777237_9765376/functions.list
@Andreas_Hegenberg - anything I can do to further help debug this?
It lags my laptop (notice how MAMP already uses half of the CPU, which is unfortunate but nothing new. Having the "background" helper BTT using up almost the entire other half is suboptimal.)
