I have an app called "Mission Control Plus" that lets me close the window under trackpad pointer when I am in the mission control. All you have to do is move your pointer to the window you wanted to be closed and press CMD+W to close the underlying window.
Having also BTT, I set up a trackpad gesture that sends CMD+W keyboard combination to close tabs/windows under the cursor (this becomes super useful in web browsing by the way.) However, what I noticed is that, in mission control, BTT trackpad to keyboard transformation does not stack with the Mission Control Plus app's features. That is, I can still close windows under my cursor if I use the keyboard combination (i.e. I press manually CMD+W) with the help of that Mission Control Plus app. However, if I keep the Mission Control Plus app on and have BTT send (via a trackpad gesture) the "CMD+W" keyboard press, nothing happens in mission control.
I am aware that there is a "Close windows below cursor (works in mission control) option" in one of the options in BTT, however, that option does not really do the same thing as CMD+W, I want to be able to close tabs very quickly with a trackpad gesture "Close windows below cursor (works in mission control) option" doesn’t do that.
I hope my problem is clear and there is a fix for this problem.
"Trackpad Gesture to send a Keyboard Combination" feature of BTT
- Type of Mac: 15" Mac (Late Fall 2016)
- macOS version: Catalina (10.15.5)
- BetterTouchTool version: 3.373
You may perhaps need to contact the "Mission Control Plus" app developer: https://www.fadel.io/missioncontrolplus
