Note:
Checked this, no regular nor alpha updates available.
Odd things are happening to my external mouse, regardless of which mouse I'm using. At first the left and right clicks were switched, then after I restarted my machine, scroll down minimizes windows and scroll up toggles between maximizing them and unmaximizing. There is no configuration I've ever set up to make this happen. It's definitely BTT because when I quit BTT, the problem goes away, and vice versa.
Various external mouse peripherals.
N/A
- Type of Mac: M1 Pro MacBook Pro
- macOS version: Sequoia 15.2
- BetterTouchTool version: Version 5.070 (2025011403)
This makes the app unusable - I keep minimizing windows every two seconds.
