Just an FYI - on my M1 mac mini running the Sonoma 14.2.1 and BBT 4.356, BBT is still not responding after waking from sleep and logging in. I currently have been restarting BBT but will try the changing the input focus window. Thanks!
also make sure to disable the experimental dropbox or icloud sync. It has been causing weird issues since a recent macOS update.
As of this week, BTT has fully stopped working for me (I only use keyboard shortcuts). I have disabled iCloud sync, but the product is really disrupting my work by being fully unfunctional at the moment.
I'm running Sonoma on the latest BTT version
Bro 2 of my 3 laptops have just not worked for the past 2 months and its crickets. Quite unfortunate given how much muscle memory I've developed for my hotkeys. Time to switch apps?
If you want you can go to Help => Export Diagnostic Debug Information and send the result to me (andreas@folivora.ai), then I can probably tell what is wrong.
Sent, thanks. I truly miss BTT
Your BTT is disabled (can happen when sync errors occur).
Have you already tried to just enable it again?
I'd recommend to disable any icloud or dropbox sync, in your logs it looks like it might still be active
I re-enabled and everything is working. It feels so good to be back after 2 months omg. I wasn't able to solve this myself. I hope others find this if needed. I didn't even have the menu bar activated for the app, and I don't see enable anywhere else in the UI
Thank you for looking at my logs
