Hi, I've had to reset my MacBook and totally forgot to export and save my BTT set up, I do have a Time Machine backup but I don't want restore to the backup itself, but of course I can dig around the files and find (hopefully) the BTT set up. I hope that makes sense, sorry if I didn't describe what I want to do correctly. Thank you for the help.
Look for this folder: ~/Library/Application Support/BetterTouchTool (go there via Finder => Go => Go to Folder, make sure to include the ~)
Thank you, so I found the folder but now I'm not sure what files/folders from there that I am supposed to copy into the current version of the App Support/BTT folder. I've restored all of them but BTT configuration window still doesn't show any of the previous data
did you quit btt before copying the files?
Oh I'm so glad I asked here. That was it, I deleted what I had copied, then quit BTT, then the the restore for that folder from Time Machine backup again. Everything popped back up like it was before. Thank you so much! Saved me a lot of time!
