Very often, if I resize windows... I can't get them back to the original shape. I've been testing some different scenarios, but I can't seem to be able to reproduce it on demand. Once I open BetterTouchTool window, it usually starts working (sometimes I have to enable/disable the affected shortcut), at least for a while.
I know the following comment "sucks", but... this didn't happen to me before and I use this feature all the time. Could this be due to Mojave?
MackBook Pro 13" 2016
Keyboard shortcut:
BetterTouchTool version: 2.660 (but problems started already before)
Just let me know what you want, and I will do my best to produce it.
I'm also seeing an issue with restore old window size. I use the "move window to next monitor" function, as well as "maximize window" function. I had expected that pressing "restore old window size" would return the window to being the same size and monitor as previous to pressing "maximize window" but the window ends up being on a different monitor.
Update!
I might to do some more digging... but I think that I can reproduce it. If I for example open iTerm2 and maximize it, or maximize it to just one half, or whatever... and then try to go back to it's original shape and place, it works. But if I start open/close tabs on it and then try to get back to it's original shape, then nothing happens. I saw some tendencies of the above at work today.
By the way... I have also tested this on a new MacBook Pro 13" M1 running and the older Mac I started this thread with, both with new installs of BigSur... still the same problem.
Otherwise... Everything works and I'm a happy camper.
Keep up the good work!
//JC
Hmmm I'd tried to bind Restore Old Window Size to OPTION+CMD+Z. I then created a random new browser window, changed its size, press the keyboard shortcut and nothing happens. Maybe I misunderstanding how to use this?
