Basically, after some time and normal computer usage, BTT stops working completely. It does not freeze or anything, it just doesn't do any of the configured gestures. The only way to make it work is by restarting the tool endlessly, which obviously is not a solution
MacBook Trackpad
- Type of Mac: 13-inch, 2017, Four Thunderbolt 3 Ports (Touchbar)
- macOS version: 10.13.6 (17G65)
- BetterTouchTool version: 2.636
