BTT Remote over Bluetooth?
Would it be possible to use Apple's multi-peer-connection framework to allow BTT remote to connect over bluetooth?
I'd love to use it at work but my iPhone isn't allowed on the same network my computer is - however airdrop IS enabled between the two devices.
Any chance of this?
I have also asked for this and I am still waiting....
Please everyone let's keep this Bluetooth topic going. I too had some of the frustrations others have complained about.. Relying on the Wi-Fi has all kinds of issues in so many different situations..
Using Bluetooth control for the cursor is without a doubt 100% better for that part of the remote app.
There is much that Wi-Fi is needed for, but in other apps the performance is just basically the same as better touch tool with Wi-Fi for the curser, and without as much preferential controls.
The moment I turn on Bluetooth, it becomes intuitive, simple to use, and the dream come true. The other apps disable a bunch of features that Wi-Fi is required for, but I can just quickly connect to the Wi-Fi for those.
Please bring Bluetooth as an option for things it improves and are available on the remote app. The fidelity is much needed.
Many of the amazing features included in the remote app will, and must require Wi-Fi. But the primary reason I got better touch tool was because I wanted a better replacement for my old junkie untrustworthy remote app.
I was excited to be using better touch tool today and especially anxious to enjoy and utilize all the great features of the remote app which surely if I get these sensitivity and variable adjustments, just write will be just un frustrating enough to use until my battery is charged.
I am here now, using some junkie old Remote App (the green one) because the dumb apple mouse needs a charge and continuity is maybe upset with this open core orgy over here.
I basically discovered and found BetterTouchTool, because I was once again looking for something better than the semi-junkie, untrustful app that I had been using. I was happy to find this software and thought it was amazing how much you did with the remote control app, And that was just the tip of the iceberg.
