Note:
When connected to either a USB C or thunderbolt dock, BTT just quits> It opens up for a brief moment and just crashes. As soon as I disconnect from the dock and launch BTT it works just fine.
- Type of Mac: 14" M1 Pro Macbook Pro
- macOS version: 13.4.1
- BetterTouchTool version: 4.173-2391(please post the exact version - not just "the latest one")
Full Report
Summary
{"app_name":"BetterTouchTool","timestamp":"2023-07-17 08:55:09.00 -0700","app_version":"4.173","slice_uuid":"d12b6d18-1e61-32dc-967c-dfd41ce86048","build_version":"2391","platform":1,"bundleID":"com.hegenberg.BetterTouchTool","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 13.4.1 (22F770820d)","roots_installed":0,"name":"BetterTouchTool","incident_id":"C77D6CA6-F60C-40B1-98E8-2036174F1609"}
"uptime" : 40000,
"procRole" : "Default",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "MacBookPro18,3",
"coalitionID" : 5304,
"osVersion" : {
"train" : "macOS 13.4.1",
"build" : "22F770820d",
"releaseType" : "User"
"captureTime" : "2023-07-17 08:55:09.1286 -0700",
"incident" : "C77D6CA6-F60C-40B1-98E8-2036174F1609",
"pid" : 10077,
"translated" : false,
"cpuType" : "ARM-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2023-07-17 08:55:04.4061 -0700",
"procStartAbsTime" : 968790713847,
"procExitAbsTime" : 968903883646,
"procName" : "BetterTouchTool",
"procPath" : "/Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool",
"bundleInfo" : {"CFBundleShortVersionString":"4.173","CFBundleVersion":"2391","CFBundleIdentifier":"com.hegenberg.BetterTouchTool"},
"storeInfo" : {"deviceIdentifierForVendor":"88A041FC-EAB9-532C-B16A-607055A8E74E","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "com.hegenberg.BetterTouchTool",
"crashReporterKey" : "7D13B3D0-F185-83BE-0FFD-CE23FCA776C6",
"codeSigningID" : "com.hegenberg.BetterTouchTool",
"codeSigningTeamID" : "DAFVSXZ82P",
"codeSigningFlags" : 570512129,
"codeSigningValidationCategory" : 6,
"codeSigningTrustLevel" : 0,
"wakeTime" : 375,
"sleepWakeUUID" : "99D4EBEE-986A-476E-818E-04528B03A47D",
"sip" : "enabled",
"exception" : {"codes":"0x0000000000000001, 0x000000018a07be48","rawCodes":[1,6610730568],"type":"EXC_BREAKPOINT","signal":"SIGTRAP"},
"termination" : {"flags":0,"code":5,"namespace":"SIGNAL","indicator":"Trace/BPT trap: 5","byProc":"exc handler","byPid":10077},
"os_fault" : {"process":"BetterTouchTool"},
"ktriageinfo" : "VM - (arg = 0x0) pmap_enter retried due to resource shortage\nVM - (arg = 0x0) pmap_enter retried due to resource shortage\nVM - (arg = 0x0) pmap_enter retried due to resource shortage\nVM - (arg = 0x0) pmap_enter retried due to resource shortage\nVM - (arg = 0x0) pmap_enter retried due to resource shortage\n",
"asi" : {"CoreFoundation":["*** CFEqual() called with NULL first argument *"]},
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 0,
"threads" : [{"triggered":true,"id":556740,"threadState":{"x":[{"value":0},{"value":8151927064},{"value":8135036288,"symbolLocation":0,"symbol":"OBJC_CLASS_$___NSCFType"},{"value":18446744073709551611},{"value":0},{"value":0},{"value":103},{"value":3328},{"value":6612471817,"symbolLocation":7877,"symbol":"_XMLPlistAppendDataUsingBase64._CFPLDataEncodeTable"},{"value":8140181504,"symbolLocation":6792,"symbol":"last_exception_backtrace"},{"value":0},{"value":31},{"value":7},{"value":5341516272},{"value":72057602172964229,"symbolLocation":72057594037927941,"symbol":"OBJC_CLASS$__NSCFType"},{"value":8135036288,"symbolLocation":0,"symbol":"OBJC_CLASS$___NSCFType"},{"value":6608787172,"symbolLocation":0,"symbol":"CFEqual"},{"value":8213744992},{"value":0},{"value":0},{"value":356355},{"value":0},{"value":0},{"value":105553116520320},{"value":4722486672},{"value":5341947216},{"value":0},{"value":105553126928512},{"value":5341947216}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6608788432},"cpsr":{"value":1610616832},"fp":{"value":6133473280},"sp":{"value":6133473264},"esr":{"value":4060086273,"description":"(Breakpoint) brk 1"},"pc":{"value":6610730568,"matchesCrashFrame":1},"far":{"value":4334167240}},"queue":"com.apple.main-thread","frames":[{"imageOffset":1986120,"symbol":"CFEqual.cold.1","symbolLocation":16,"imageIndex":15},{"imageOffset":43984,"symbol":"CFEqual","symbolLocation":1260,"imageIndex":15},{"imageOffset":2088648,"symbol":"SLSManagedDisplayGetCurrentSpace","symbolLocation":68,"imageIndex":16},{"imageOffset":763160,"imageIndex":0},{"imageOffset":1593456,"imageIndex":0},{"imageOffset":10356,"symbol":"_dispatch_call_block_and_release","symbolLocation":32,"imageIndex":17},{"imageOffset":17408,"symbol":"_dispatch_client_callout","symbolLocation":20,"imageIndex":17},{"imageOffset":76792,"symbol":"_dispatch_main_queue_drain","symbolLocation":928,"imageIndex":17},{"imageOffset":75848,"symbol":"_dispatch_main_queue_callback_4CF","symbolLocation":44,"imageIndex":17},{"imageOffset":789588,"symbol":"CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE","symbolLocation":16,"imageIndex":15},{"imageOffset":517076,"symbol":"__CFRunLoopRun","symbolLocation":1992,"imageIndex":15},{"imageOffset":513208,"symbol":"CFRunLoopRunSpecific","symbolLocation":612,"imageIndex":15},{"imageOffset":199744,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":18},{"imageOffset":199292,"symbol":"ReceiveNextEventCommon","symbolLocation":648,"imageIndex":18},{"imageOffset":198612,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":76,"imageIndex":18},{"imageOffset":232772,"symbol":"_DPSNextEvent","symbolLocation":636,"imageIndex":19},{"imageOffset":229088,"symbol":"-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":716,"imageIndex":19},{"imageOffset":181060,"symbol":"-[NSApplication run]","symbolLocation":464,"imageIndex":19},{"imageOffset":14228,"symbol":"NSApplicationMain","symbolLocation":880,"imageIndex":19},{"imageOffset":24360,"symbol":"start","symbolLocation":2236,"imageIndex":20}]},{"id":556868,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":21}]},{"id":556869,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":21}]},{"id":556870,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":21}]},{"id":556874,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":21}]},{"id":556877,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":21}]},{"id":556878,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":21}]},{"id":556879,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":21}]},{"id":556880,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":21}]},{"id":556941,"name":"com.apple.NSURLConnectionLoader","frames":[{"imageOffset":3860,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":22},{"imageOffset":78400,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":22},{"imageOffset":39800,"symbol":"mach_msg_overwrite","symbolLocation":604,"imageIndex":22},{"imageOffset":4752,"symbol":"mach_msg","symbolLocation":24,"imageIndex":22},{"imageOffset":522212,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":15},{"imageOffset":516292,"symbol":"__CFRunLoopRun","symbolLocation":1208,"imageIndex":15},{"imageOffset":513208,"symbol":"CFRunLoopRunSpecific","symbolLocation":612,"imageIndex":15},{"imageOffset":2444248,"imageIndex":23},{"imageOffset":353612,"symbol":"NSThread__start","symbolLocation":716,"imageIndex":24},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":21},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":21}]},{"id":556954,"name":"com.apple.NSEventThread","frames":[{"imageOffset":3860,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":22},{"imageOffset":78400,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":22},{"imageOffset":39800,"symbol":"mach_msg_overwrite","symbolLocation":604,"imageIndex":22},{"imageOffset":4752,"symbol":"mach_msg","symbolLocation":24,"imageIndex":22},{"imageOffset":522212,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":15},{"imageOffset":516292,"symbol":"__CFRunLoopRun","symbolLocation":1208,"imageIndex":15},{"imageOffset":513208,"symbol":"CFRunLoopRunSpecific","symbolLocation":612,"imageIndex":15},{"imageOffset":1454900,"symbol":"_NSEventThread","symbolLocation":172,"imageIndex":19},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":21},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":21}]},{"id":556972,"queue":"com.apple.root.user-initiated-qos","frames":[{"imageOffset":6504,"symbol":"__open","symbolLocation":8,"imageIndex":22},{"imageOffset":51844,"symbol":"open","symbolLocation":64,"imageIndex":22},{"imageOffset":150772,"symbol":"_NSReadBytesFromFileWithExtendedAttributes","symbolLocation":152,"imageIndex":24},{"imageOffset":5495972,"symbol":"-[_NSBPlistMappedData initWithFileURL:error:]","symbolLocation":108,"imageIndex":24},{"imageOffset":5495520,"symbol":"__NSCreateBPlistMappedDataFromURL","symbolLocation":88,"imageIndex":24},{"imageOffset":1778160,"symbol":"_CFBundleMapStringsFile","symbolLocation":92,"imageIndex":15},{"imageOffset":1775700,"symbol":"_CFBundleGetStringsSources","symbolLocation":384,"imageIndex":15},{"imageOffset":1782648,"symbol":"_copyStringTable","symbolLocation":200,"imageIndex":15},{"imageOffset":1781452,"symbol":"_CFBundleCopyLocalizedStringForLocalizationTableURLAndMarkdownOption","symbolLocation":164,"imageIndex":15},{"imageOffset":176480,"symbol":"-[NSBundle localizedStringForKey:value:table:]","symbolLocation":56,"imageIndex":24},{"imageOffset":989016,"symbol":"+[CIFilterClassAttributes _attributesWithClass:]","symbolLocation":312,"imageIndex":25},{"imageOffset":990640,"symbol":"+[CIFilterClassAttributes classAttributesForClass:]","symbolLocation":248,"imageIndex":25},{"imageOffset":386348,"symbol":"+[CUIShapeEffectStack outerShadowFrom:withOffset:size:spread:red:green:blue:opacity:]","symbolLocation":168,"imageIndex":26},{"imageOffset":120500,"symbol":"-[CUIShapeEffectStack standardEffectCompositeWithShapeImage:blendOntoImage:]","symbolLocation":916,"imageIndex":26},{"imageOffset":866640,"symbol":"-[_CUIGraphicVariantVectorGlyph _createGraphicVariantImageAtScale:backgroundImage:symbolImage:destinationRect:disableColorFill:outputScale:]","symbolLocation":184,"imageIndex":26},{"imageOffset":862220,"symbol":"-[_CUIGraphicVariantVectorGlyph rasterizeImageUsingScaleFactor:forTargetSize:]","symbolLocation":264,"imageIndex":26},{"imageOffset":40940,"symbol":"-[IFSymbol imageForGraphicSymbolDescriptor:]","symbolLocation":856,"imageIndex":27},{"imageOffset":183276,"symbol":"+[SHKSharingService _createServiceImageFromSymbolNamed:backgroundColor:]","symbolLocation":412,"imageIndex":28},{"imageOffset":81540,"symbol":"-[SHKSharePlaySharingService init]","symbolLocation":240,"imageIndex":28},{"imageOffset":198724,"symbol":"+[SHKSharingService builtInSharingServicesForItems:]","symbolLocation":72,"imageIndex":28},{"imageOffset":198516,"symbol":"__113+[SHKSharingService sharingServicesForFilteredItems:invokedByPicker:allowInactive:onlyViewerOrEditor:completion:]_block_invoke.458","symbolLocation":860,"imageIndex":28},{"imageOffset":10356,"symbol":"_dispatch_call_block_and_release","symbolLocation":32,"imageIndex":17},{"imageOffset":17408,"symbol":"_dispatch_client_callout","symbolLocation":20,"imageIndex":17},{"imageOffset":90040,"symbol":"_dispatch_root_queue_drain","symbolLocation":684,"imageIndex":17},{"imageOffset":91840,"symbol":"_dispatch_worker_thread2","symbolLocation":164,"imageIndex":17},{"imageOffset":12344,"symbol":"_pthread_wqthread","symbolLocation":228,"imageIndex":21},{"imageOffset":7572,"symbol":"start_wqthread","symbolLocation":8,"imageIndex":21}]},{"id":556973,"queue":"com.apple.root.user-initiated-qos","frames":[{"imageOffset":15304,"symbol":"__psynch_mutexwait","symbolLocation":8,"imageIndex":22},{"imageOffset":16580,"symbol":"_pthread_mutex_firstfit_lock_wait","symbolLocation":84,"imageIndex":21},{"imageOffset":6748,"symbol":"_pthread_mutex_firstfit_lock_slow","symbolLocation":248,"imageIndex":21},{"imageOffset":990520,"symbol":"+[CIFilterClassAttributes classAttributesForClass:]","symbolLocation":128,"imageIndex":25},{"imageOffset":386348,"symbol":"+[CUIShapeEffectStack outerShadowFrom:withOffset:size:spread:red:green:blue:opacity:]","symbolLocation":168,"imageIndex":26},{"imageOffset":120500,"symbol":"-[CUIShapeEffectStack standardEffectCompositeWithShapeImage:blendOntoImage:]","symbolLocation":916,"imageIndex":26},{"imageOffset":866640,"symbol":"-[_CUIGraphicVariantVectorGlyph _createGraphicVariantImageAtScale:backgroundImage:symbolImage:destinationRect:disableColorFill:outputScale:]","symbolLocation":184,"imageIndex":26},{"imageOffset":862220,"symbol":"-[_CUIGraphicVariantVectorGlyph rasterizeImageUsingScaleFactor:forTargetSize:]","symbolLocation":264,"imageIndex":26},{"imageOffset":40940,"symbol":"-[IFSymbol imageForGraphicSymbolDescriptor:]","symbolLocation":856,"imageIndex":27},{"imageOffset":183276,"symbol":"+[SHKSharingService _createServiceImageFromSymbolNamed:backgroundColor:]","symbolLocation":412,"imageIndex":28},{"imageOffset":81540,"symbol":"-[SHKSharePlaySharingService init]","symbolLocation":240,"imageIndex":28},{"imageOffset":198724,"symbol":"+[SHKSharingService builtInSharingServicesForItems:]","symbolLocation":72,"imageIndex":28},{"imageOffset":198516,"symbol":"__113+[SHKSharingService sharingServicesForFilteredItems:invokedByPicker:allowInactive:onlyViewerOrEditor:completion:]_block_invoke.458","symbolLocation":860,"imageIndex":28},{"imageOffset":10356,"symbol":"_dispatch_call_block_and_release","symbolLocation":32,"imageIndex":17},{"imageOffset":17408,"symbol":"_dispatch_client_callout","symbolLocation":20,"imageIndex":17},{"imageOffset":90040,"symbol":"_dispatch_root_queue_drain","symbolLocation":684,"imageIndex":17},{"imageOffset":91840,"symbol":"_dispatch_worker_thread2","symbolLocation":164,"imageIndex":17},{"imageOffset":12344,"symbol":"_pthread_wqthread","symbolLocation":228,"imageIndex":21},{"imageOffset":7572,"symbol":"start_wqthread","symbolLocation":8,"imageIndex":21}]},{"id":557019,"name":"JavaScriptCore libpas scavenger","frames":[{"imageOffset":18192,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":22},{"imageOffset":30068,"symbol":"_pthread_cond_wait","symbolLocation":1232,"imageIndex":21},{"imageOffset":2614736,"symbol":"scavenger_thread_main","symbolLocation":1428,"imageIndex":29},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":21},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":21}]},{"id":557025,"name":"com.apple.coreanimation.render-server","frames":[{"imageOffset":3860,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":22},{"imageOffset":78400,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":22},{"imageOffset":39800,"symbol":"mach_msg_overwrite","symbolLocation":604,"imageIndex":22},{"imageOffset":4752,"symbol":"mach_msg","symbolLocation":24,"imageIndex":22},{"imageOffset":293372,"symbol":"CA::Render::Server::server_thread(void)","symbolLocation":564,"imageIndex":30},{"imageOffset":292792,"symbol":"thread_fun(void)","symbolLocation":32,"imageIndex":30},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":21},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":21}]},{"id":557078,"frames":[{"imageOffset":3860,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":22},{"imageOffset":78400,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":22},{"imageOffset":39800,"symbol":"mach_msg_overwrite","symbolLocation":604,"imageIndex":22},{"imageOffset":4752,"symbol":"mach_msg","symbolLocation":24,"imageIndex":22},{"imageOffset":522212,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":15},{"imageOffset":516292,"symbol":"__CFRunLoopRun","symbolLocation":1208,"imageIndex":15},{"imageOffset":513208,"symbol":"CFRunLoopRunSpecific","symbolLocation":612,"imageIndex":15},{"imageOffset":1058172,"symbol":"CFRunLoopRun","symbolLocation":64,"imageIndex":15},{"imageOffset":21468,"symbol":"mt_ThreadedMTEntry","symbolLocation":72,"imageIndex":31},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":21},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":21}]}],
"usedImages" : [
"source" : "P",
"arch" : "arm64",
"base" : 4333404160,
"CFBundleShortVersionString" : "4.173",
"CFBundleIdentifier" : "com.hegenberg.BetterTouchTool",
"size" : 12124160,
"uuid" : "d12b6d18-1e61-32dc-967c-dfd41ce86048",
"path" : "/Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool",
"name" : "BetterTouchTool",
"CFBundleVersion" : "2391"
"source" : "P",
"arch" : "arm64",
"base" : 4350541824,
"CFBundleShortVersionString" : "1.5",
"CFBundleIdentifier" : "com.mixedinkey.MIKMIDI",
"size" : 327680,
"uuid" : "16ddf028-19de-3847-bbd4-8c164b405d1f",
"path" : "/Applications/BetterTouchTool.app/Contents/Frameworks/MIKMIDI.framework/Versions/A/MIKMIDI",
"name" : "MIKMIDI",
"CFBundleVersion" : "877"
"source" : "P",
"arch" : "arm64",
"base" : 4349493248,
"CFBundleIdentifier" : "net.wafflesoftware.ShortcutRecorder.framework.Leopard",
"size" : 49152,
"uuid" : "1f28ebb9-986a-3e5a-b15c-01183c53a265",
"path" : "/Applications/BetterTouchTool.app/Contents/Frameworks/ShortcutRecorder.framework/Versions/A/ShortcutRecorder",
"name" : "ShortcutRecorder",
"CFBundleVersion" : "1.0"
"source" : "P",
"arch" : "arm64",
"base" : 4349640704,
"CFBundleShortVersionString" : "2.2.1",
"CFBundleIdentifier" : "org.sparkle-project.Sparkle",
"size" : 360448,
"uuid" : "998f01d4-1e73-3cec-a0c6-5a49be01dbf5",
"path" : "/Applications/BetterTouchTool.app/Contents/Frameworks/Sparkle.framework/Versions/B/Sparkle",
"name" : "Sparkle",
"CFBundleVersion" : "2017"
"source" : "P",
"arch" : "arm64",
"base" : 4352983040,
"CFBundleShortVersionString" : "2.6",
"CFBundleIdentifier" : "com.mentalfaculty.ensembles",
"size" : 524288,
"uuid" : "b2228155-dcf8-36c0-8089-894de12517f1",
"path" : "/Applications/BetterTouchTool.app/Contents/Frameworks/Ensembles.framework/Versions/A/Ensembles",
"name" : "Ensembles",
"CFBundleVersion" : "1"
"source" : "P",
"arch" : "arm64",
"base" : 4349378560,
"CFBundleShortVersionString" : "1.0",
"CFBundleIdentifier" : "com.hegenberg.BTTPluginSupport",
"size" : 16384,
"uuid" : "8544739d-8d4d-319f-bd3f-e505148b2242",
"path" : "/Applications/BetterTouchTool.app/Contents/Frameworks/BTTPluginSupport.framework/Versions/A/BTTPluginSupport",
"name" : "BTTPluginSupport",
"source" : "P",
"arch" : "arm64",
"base" : 4349181952,
"CFBundleShortVersionString" : "1.25",
"CFBundleIdentifier" : "com.potionfactory.LetsMove",
"size" : 16384,
"uuid" : "4cccd167-7048-39ff-a5c4-594f5fa5e57a",
"path" : "/Applications/BetterTouchTool.app/Contents/Frameworks/LetsMove.framework/Versions/A/LetsMove",
"name" : "LetsMove",
"CFBundleVersion" : "125"
"source" : "P",
"arch" : "arm64e",
"base" : 4520738816,
"size" : 49152,
"uuid" : "570c31f7-94c6-3b86-ae44-1694db0a4bcd",
"path" : "/usr/lib/libobjc-trampolines.dylib",
"name" : "libobjc-trampolines.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 4548214784,
"CFBundleShortVersionString" : "2.0.0",
"CFBundleIdentifier" : "com.apple.iokit.IOHIDLib",
"size" : 98304,
"uuid" : "22732249-8ca0-386a-99b3-a948420926bf",
"path" : "/System/Library/Extensions/IOHIDFamily.kext/Contents/PlugIns/IOHIDLib.plugin/Contents/MacOS/IOHIDLib",
"name" : "IOHIDLib",
"CFBundleVersion" : "2.0.0"
"source" : "P",
"arch" : "arm64e",
"base" : 4546723840,
"CFBundleIdentifier" : "com.apple.CloudDocsFileProvider",
"size" : 32768,
"uuid" : "017e043e-5737-3068-9b3a-ddb9a40d7896",
"path" : "/System/Library/Frameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider",
"name" : "CloudDocsFileProvider",
"CFBundleVersion" : "1553.120.155"
"source" : "P",
"arch" : "arm64e",
"base" : 4546543616,
"CFBundleShortVersionString" : "855.121.1",
"CFBundleIdentifier" : "com.apple.FileProviderOverride",
"size" : 32768,
"uuid" : "96bff6ca-1a7e-3003-bbbb-c1a2840a2159",
"path" : "/System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride",
"name" : "FileProviderOverride",
"CFBundleVersion" : "855.121.1"
"source" : "P",
"arch" : "arm64e",
"base" : 4547690496,
"CFBundleShortVersionString" : "13.4",
"CFBundleIdentifier" : "com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride",
"size" : 131072,
"uuid" : "b463deea-6610-346d-bd23-63b7501604c6",
"path" : "/System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride",
"name" : "FinderSyncCollaborationFileProviderOverride",
"CFBundleVersion" : "1564.6.2"
"source" : "P",
"arch" : "arm64e",
"base" : 4553080832,
"CFBundleShortVersionString" : "3.0",
"CFBundleIdentifier" : "com.apple.security.csparser",
"size" : 131072,
"uuid" : "ab8de20f-ecaa-3540-8abe-fcf57e740bec",
"path" : "/System/Library/Frameworks/Security.framework/Versions/A/PlugIns/csparser.bundle/Contents/MacOS/csparser",
"name" : "csparser",
"CFBundleVersion" : "60420.121.2"
"source" : "P",
"arch" : "arm64e",
"base" : 4553326592,
"CFBundleIdentifier" : "com.apple.AppleMetalOpenGLRenderer",
"size" : 442368,
"uuid" : "01596a35-894c-3104-8314-40d3c08f18ca",
"path" : "/System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/MacOS/AppleMetalOpenGLRenderer",
"name" : "AppleMetalOpenGLRenderer",
"source" : "P",
"arch" : "arm64e",
"base" : 5074059264,
"CFBundleShortVersionString" : "7.0",
"CFBundleIdentifier" : "com.apple.audio.codecs.Components",
"size" : 6438912,
"uuid" : "e31ed697-7d0f-30de-99cb-81600bf772a8",
"path" : "/System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs",
"name" : "AudioCodecs",
"CFBundleVersion" : "7.0"
"source" : "P",
"arch" : "arm64e",
"base" : 6608744448,
"CFBundleShortVersionString" : "6.9",
"CFBundleIdentifier" : "com.apple.CoreFoundation",
"size" : 5087232,
"uuid" : "203e4401-8c2e-3157-a24b-92f52551d43e",
"path" : "/System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation",
"name" : "CoreFoundation",
"CFBundleVersion" : "1977"
"source" : "P",
"arch" : "arm64e",
"base" : 6688985088,
"CFBundleShortVersionString" : "1.600.0",
"CFBundleIdentifier" : "com.apple.SkyLight",
"size" : 4374528,
"uuid" : "96676a53-b1e0-3d7e-b98b-b73873cd1880",
"path" : "/System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight",
"name" : "SkyLight"
"source" : "P",
"arch" : "arm64e",
"base" : 6606569472,
"size" : 294912,
"uuid" : "c2fd3094-b465-39a4-b774-16583ff53c4b",
"path" : "/usr/lib/system/libdispatch.dylib",
"name" : "libdispatch.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 6768746496,
"CFBundleShortVersionString" : "2.1.1",
"CFBundleIdentifier" : "com.apple.HIToolbox",
"size" : 3358720,
"uuid" : "d800278b-4e6c-3032-b56f-027a938a51d6",
"path" : "/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox",
"name" : "HIToolbox"
"source" : "P",
"arch" : "arm64e",
"base" : 6661591040,
"CFBundleIdentifier" : "com.apple.AppKit",
"size" : 15790080,
"uuid" : "041c7d21-21cc-3eea-ae53-d39f5ca6a24e",
"path" : "/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit",
"name" : "AppKit",
"CFBundleVersion" : "2299.60.124"
"source" : "P",
"arch" : "arm64e",
"base" : 6604824576,
"size" : 582996,
"uuid" : "2237410f-d39c-30ce-9a94-13aacb66b766",
"path" : "/usr/lib/dyld",
"name" : "dyld"
"source" : "P",
"arch" : "arm64e",
"base" : 6608326656,
"size" : 53248,
"uuid" : "46d35233-a051-3f4f-bba4-ba56dddc4d1a",
"path" : "/usr/lib/system/libsystem_pthread.dylib",
"name" : "libsystem_pthread.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 6608089088,
"size" : 237544,
"uuid" : "34a49b54-82b2-37a1-9314-f6a4a2bb3ff8",
"path" : "/usr/lib/system/libsystem_kernel.dylib",
"name" : "libsystem_kernel.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 6684282880,
"CFBundleShortVersionString" : "1408.0.4",
"CFBundleIdentifier" : "com.apple.CFNetwork",
"size" : 3948544,
"uuid" : "0e79cb17-3ea4-33f7-8589-da01432afde4",
"path" : "/System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork",
"name" : "CFNetwork",
"CFBundleVersion" : "1408.0.4"
"source" : "P",
"arch" : "arm64e",
"base" : 6625103872,
"CFBundleIdentifier" : "com.apple.Foundation",
"size" : 10248192,
"uuid" : "d5337cc6-a075-3ca0-b5bf-b49da8878337",
"path" : "/System/Library/Frameworks/Foundation.framework/Versions/C/Foundation",
"name" : "Foundation",
"source" : "P",
"arch" : "arm64e",
"base" : 6775619584,
"CFBundleShortVersionString" : "17.0.0",
"CFBundleIdentifier" : "com.apple.CoreImage",
"size" : 3530752,
"uuid" : "780b768c-4b54-36c3-ac8e-9d6138c86592",
"path" : "/System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage",
"name" : "CoreImage",
"CFBundleVersion" : "1340.9"
"source" : "P",
"arch" : "arm64e",
"base" : 6735814656,
"CFBundleShortVersionString" : "2.1",
"CFBundleIdentifier" : "com.apple.coreui",
"size" : 1335296,
"uuid" : "1a566282-b444-3f61-b250-59e0681d30b7",
"path" : "/System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI",
"name" : "CoreUI",
"CFBundleVersion" : "804.3"
"source" : "P",
"arch" : "arm64e",
"base" : 6829408256,
"CFBundleShortVersionString" : "552",
"CFBundleIdentifier" : "com.apple.IconFoundation",
"size" : 110592,
"uuid" : "8cf23e40-daaf-3c18-a3c9-3f3eea400423",
"path" : "/System/Library/PrivateFrameworks/IconFoundation.framework/Versions/A/IconFoundation",
"name" : "IconFoundation",
"CFBundleVersion" : "552"
"source" : "P",
"arch" : "arm64e",
"base" : 7324348416,
"CFBundleShortVersionString" : "871",
"CFBundleIdentifier" : "com.apple.ShareKit",
"size" : 704512,
"uuid" : "db7b0d58-ed16-3e47-ab95-b5590c59f0f0",
"path" : "/System/Library/PrivateFrameworks/ShareKit.framework/Versions/A/ShareKit",
"name" : "ShareKit",
"CFBundleVersion" : "871"
"source" : "P",
"arch" : "arm64e",
"base" : 7047806976,
"CFBundleShortVersionString" : "18615",
"CFBundleIdentifier" : "com.apple.JavaScriptCore",
"size" : 24051712,
"uuid" : "1e0187cf-b156-32d9-bc4c-7e76bb852c44",
"path" : "/System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore",
"name" : "JavaScriptCore",
"CFBundleVersion" : "18615.2.9.11.10"
"source" : "P",
"arch" : "arm64e",
"base" : 6731816960,
"CFBundleShortVersionString" : "1.11",
"CFBundleIdentifier" : "com.apple.QuartzCore",
"size" : 3661824,
"uuid" : "cf853bbd-01b6-3f46-ada1-ec70fd2dc9dc",
"path" : "/System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore",
"name" : "QuartzCore",
"CFBundleVersion" : "1045.16"
"source" : "P",
"arch" : "arm64e",
"base" : 6839824384,
"CFBundleShortVersionString" : "6440.7",
"CFBundleIdentifier" : "com.apple.MultitouchSupport.framework",
"size" : 249856,
"uuid" : "83d12fa6-0922-3461-9cbc-9b705828b846",
"path" : "/System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport",
"name" : "MultitouchSupport",
"CFBundleVersion" : "6440.7"
"sharedCache" : {
"base" : 6604161024,
"size" : 3551657984,
"uuid" : "f5b60d87-3ee7-3c74-8415-517f8103a187"
"vmSummary" : "ReadOnly portion of Libraries: Total=1.5G resident=0K(0%) swapped_out_or_unallocated=1.5G(100%)\nWritable regions: Total=5.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=5.8G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 384K 3 \nActivity Tracing 256K 1 \nCG image 544K 14 \nCG raster data 32K 2 \nColorSync 528K 26 \nCoreAnimation 1152K 58 \nCoreData 80K 1 \nCoreData Object IDs 4112K 2 \nCoreGraphics 64K 4 \nCoreServices 208K 1 \nCoreUI image data 2160K 18 \nFoundation 16K 1 \nImage IO 32K 2 \nKernel Alloc Once 32K 1 \nMALLOC 300.5M 69 \nMALLOC guard page 288K 14 \nMALLOC_MEDIUM (reserved) 944.0M 8 reserved VM address space (unallocated)\nMALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)\nSQLite page cache 640K 5 \nSTACK GUARD 56.2M 16 \nStack 16.5M 16 \nVM_ALLOCATE 128.1M 9 \nVM_ALLOCATE (reserved) 3.9G 1 reserved VM address space (unallocated)\nWebKit Malloc 160.1M 4 \nWebKit Malloc (reserved) 32.0M 1 reserved VM address space (unallocated)\n__AUTH 2750K 461 \n__AUTH_CONST 33.2M 711 \n__CTF 824 1 \n__DATA 17.0M 712 \n__DATA_CONST 34.9M 728 \n__DATA_DIRTY 2196K 272 \n__FONT_DATA 2352 1 \n__GLSLBUILTINS 5174K 1 \n__INFO_FILTER 8 1 \n__LINKEDIT 804.5M 16 \n__OBJC_RO 66.3M 1 \n__OBJC_RW 2011K 1 \n__TEXT 741.3M 750 \ndyld private memory 272K 2 \nlibnetwork 640K 16 \nmapped file 300.4M 53 \nshared memory 928K 16 \n=========== ======= ======= \nTOTAL 7.8G 4021 \nTOTAL, minus reserved VM space 2.6G 4021 \n",
"legacyInfo" : {
"threadTriggered" : {
"queue" : "com.apple.main-thread"
"logWritingSignature" : "610925eaeac5c43f28d6f7b7efc73add3246a464",
"trialInfo" : {
"rollouts" : [
"rolloutId" : "5fb4245a1bbfe8005e33a1e1",
"factorPackIds" : {
"deploymentId" : 240000021
"rolloutId" : "62c73fd17cce0d1b0bcb8a02",
"factorPackIds" : {
"SIRI_DIALOG_ASSETS" : "648719632dccf40610e755fa"
"deploymentId" : 240000131
"experiments" : [
"treatmentId" : "c28e4ee6-1b08-4f90-8e05-2809e78310a3",
"experimentId" : "6317d2003d24842ff850182a",
"deploymentId" : 400000013
