Note:
Tested with latest regular update, 5.294, and latest alpha update, 5.301. Issue persists through restarts.
I have window dragging set to operate on the shift key. In the game Minecraft, the shift key needs to be held down to crouch. Both the Minecraft launcher and the Java window itself (added through running apps) are set to disable both window dragging and BTT entirely. However, in the game window itself, which is set to full screen, holding down shift and moving the cursor does one of two things:
- half of the time, the fullscreen window is dragged like any other window, despite window dragging being disabled for this app.
- the other half of the time, the window does not move, but the frame rate slows down to around 1 update per second while the shift key is held,
Both of these are solved entirely when BTT is quit out while the game is running.
Macbook Trackpad, bluetooth Magic Trackpad 1, USB Logitech mouse
- Type of Mac: M1 Mac mini, 2021 16" MacBook Pro
- macOS version: 15.4 on both Macs.
- BetterTouchTool version: latest regular update, 5.294, and latest alpha update, 5.301
