I would love to be able to resize the window on the current monitor. I tried '0 Screens' and it prefers the main monitor it seems.
"Current monitor" is a bit vague, do you want to use the monitor with the focused window on it? Or the monitor with the mouse cursor on it?
You should be able to select the corresponding option here:
Yes, that's it. "0 screens to the from the window display" is what I was looking for. Thanks!
