BTT Launcher group shortcut
At the moment I'm using the BTT launcher with all groups/items configured with "Prompt Match". However if I also have a "Group Shortcut" assigned like for "Bookmarks" pressing this shortcut results in nothing, the group/item should be visible so that the shortcut is working. I'm not sure if this is bug or a feature?
Mh, does opening the group manually work correctly? (It seems the group shortcuts are working fine here)
The group is not visible at launch, so I cannot test to open it manually (or I don't know how), because my launcher is empty:
If I change "Bookmarks" to be visible then its shortcut is working and I can also open manually the group.
Ah in my tests I had it visible, this might be causing the issue. I'll check!
This should be resolved in 6.808!
