BTT already has a tick in Location Services.
On resuming from sleep I am asked to Allow location
- Type of Mac: MBP 13" 2018 4 TB3 Intel
- macOS version: Monterey 12.0.1
- BetterTouchTool version: 3.626 (1778)
Unfortunately that's a macOS bug, I think it happens if the location permission database gets corrupted. You could try to run this terminal command to reset the location permission database:
tccutil reset Location
Hi Andreas
Unfortunately
returned: Failed to reset Location.
I tried tccutil reset All
That was successful.
I think this has solved the problem and I just have to re-authorise access for all other apps.
Thanks for your help and your ongoing maintenance of BTT
