i just created a new partition to try out High Sierra. i updated it to the current version, installed my BTT, registered, updated it... everything is the latest version.
opened preferences and cranked the speed up to 8 as i'm accustomed. [i'm disabled and have very limited movement in my finger. anyway...]
no change. it felt like stock speed still.
i opened the apple trackpad preferences and turned it all the way up.
barely faster.
switched back to BTT and turned it up all the way to 14.
i reset BTT's setting to start over and noticed resetting wasn't actually changing the settings. i tried 3 times and the speed remained set at 14 instead of reverting to default [isn't default 3 or 4?].
Unfortunately on recent macOS versions Apple locked the speed to the maximum that can be set in System Preferences. BetterTouchTool can currently not work around that.
Unfortunately I'm not aware of any other app that works with the current macOS versions either ;-(
(However if you find any, I't would be great if you'd let me know)
Hello Andreas.
I've had the same problem (I know this is two years later..)
I downloaded CursorSense and yes, it still works! I enjoy having my mouse on very high sensitivity, and this allowed that. So please look into it and try to fix the BTT one. I've started a 20 day free trial on CS, but I don't want to be paying for that as well as BTT when my trial is over.
Please fix this!
Thanks
unfortunately cursor sense uses a complicated hack that won’t work in the context of BTT. If you need that feature you probably need cursor sense — I don’t know of any other top that can do it.
Max in System Preferences is still 3. That's super slow.
Max in BTT is 8. But there's no difference between 3 and 8.
I can set it to pretty much what I want using defaults write to com.apple.trackpad.scaling. But nothing over 3 makes any difference.
CursorSense can't change the speed, but it can change the acceleration, and unfortunately only to max 5. But better than nothing.
