Menubar item & Context Menu item actions in BTT fail to be activated in Finder.
This is "Tags..." you could easily trigger by clicking on after right-clicking on a file.
Another way is that you could click "Tags..." from the menu bar in Finder
In BTT, there is no way to trigger the "Tags..." action. I tried this one with "Trigger Menubar Menu-Item" as "File;Tags..." and it does not work.
I also tried Context Menu actions but again, it failed to trigger.
The same thing happens with Share. I used Dropover in sharing.
I tried the same thing with Menubar-Item
And somehow with Trigger Context Menu Item, it does work but with minimal twist of error. If you can see, I added F9 as keyboard shortcut to "Move focus to active or next window". The reason I did add the focus is that when I trigger with Context Menu item in BTT, it always pops up a context menu (as when you right-click) again after the action is done; and the focus would close the unnecessary context menu pop-up the second time.
I just hope these errors/bugs would be fixed.
Thank you so much for your listening.
- Type of Mac: MacBook Pro (16-inch, 2019), 2.3 GHz 8-Core Intel Core i9
- macOS version: Monterey
- BetterTouchTool version: 3.616
