I have disabled force click in system settings. I do not use it, and I do not want to use it. When I click on my trackpad, I want it to register as a click, not as a force click.
However, after I updated BTT recently, now clicks with 3 or more fingers become force clicks when I press firmly, which I do not want. This only happens while BTT is running, and it only affects 3+ finger clicks.
If I quit BTT then force clicks are properly disabled, in accordance with my system setting. I want that to remain the case when I have BTT open. It used to work properly before I updated BTT, though I don’t remember which version I had before updating.
MacBook Air trackpad
- Type of Mac: M3 MBA
- macOS version: 26.4.1
- BetterTouchTool version: 6.506
