BTT Hyper Key Issue
Hello, I have been using Karabiner to map my caps lock key to the hyper key. I recently saw BTT added this functionality so uninstalled Karabiner and set up the caps lock key as the hyper key in BTT. The functionality seems to work for shortcuts in BTT, but when I try using with a Keyboard Maestro shortcut I have set up for DEVONthink (hyper key + I) to insert the current date before a file name, the BTT hyper key shortcut either doesn't do anything or triggers a completely different shortcut (hyper key + D) along with moving the DEVONthink screen to my second monitor. That screen movement is another BTT shortcut (hyper key + left arrow) so perhaps BTT is struggling to interpret the hyper key + I for Keyboard Maestro versus other hyper key combinations build into BTT?
I'm struggling to figure out why the hyper key works within BTT but fails or has strange behavior when used in combination with Keyboard Maestro and DEVONthink.
Thanks in advance your help!
