Hello everyone.
Since recently upgrading to Catalina (I know, I'm late) I'm missing the dashboard for unit/currency conversions. I use Launchbar as my launcher, but I know spotlight is pretty good at conversions so I tried setting my previous dashboard gesture to launch spotlight but I can't get it to work consistently. For reference the gesture is 4 finger swipe down. The gesture even doesn't work for triggering the command-space shortcut (I can physically use command-space no problems).
I can occasionally get it to register when I switch between the key down/key up and down dropdown menu and save, but even then it works once, and sometimes twice and stops. I've also tried various other simpler gestures to no avail.
Is this s BTT bug or some deeper level MacOS thing?
Thanks for any info!
