Battery life drops from 8 hours to 4 hours with BTT running. No presets installed. Let me know if there's any files I can send you. Currently have BTT uninstalled since the hit to battery life is too great.
This pretty much depends on what kind of scripts and actions you are using in BTT. In general try to reduce refresh rates for apple script widgets and the like.
If you have the experimental dropbox sync enabled, try to disable that for now, there seem to be some issues with that.
For sure. I've been using BTT and Golden Chaos since 2017 and I just noticed a huge drop in battery life this past week and Activity Monitor is blaming BTT, so first I looked around in GC, which has an apple script to look for updates run every 5 seconds, I disabled that, then I just uninstalled BTT and GC and reinstalled it and ran BTT stock with no scripts and I was still getting the battery drain. I don't use dropbox sync. Is there any sort of indexing that BTT does after a new install that perhaps I give it a day or two to settle? I also don't use the window snapping because I have yabai running as my window manager and skhd as my shortcut manager. Here's a link: https://github.com/koekeishiya/yabai/wiki. Do you think it could be interfering now even though it hasn't been an issue for the past year?
Any idea how to stop these insane number of apple script wake ups? Pretty sure this is why battery life is so poor.BetterTouchToolAppleScriptRunner_2020-02-10-122833-MacBook-Pro.wakeups_resource.diag.zip (5.2 KB)
reduce the refreshrate for the used apple scripts, unfortunately you’d need to do this for all the scripts manually at the moment.
The recent alphas improve energy usage a bit, but if many scripts are used that constantly refresh it will still be similar.
Hmm...I get the same issue even on a clean install of BTT. I picked an old install from May 22 2019 and the high energy issue was not there. Activity monitor went from 20 down to 0.2.
BetterTouchTool doesn't do much if it doesn't have any triggers configured, especially there won't run any Apple Scripts. To do a real clean install delete ~/Library/Application Support/BetterTouchTool while BTT is quit.
If you run a older version it won't load the newer configuration files which would explain that.
