BTT crashes within Floating Menu when using "Reset Floating Menu / Item Properties"
Hi Andreas,
I wanted to use the "Update Floating Menu ITEM properties" action to make the item I hover slightly bigger.
  • BTT crashes reproducible when using the Floating Menu attached at the bottom
  • It seems to be because of the "Update Floating Menu ITEM properties" action
  • See also vidoe for details
  • Type of Mac: MacBook Pro M4
  • macOS version: 26.3
  • BetterTouchTool version: 6.194
Test-Ring.bttpreset (89.9 KB)
I could work around the problem by using another "Update Floating Menu ITEM properties" action instead of the "Reset Floating Menu / Item Properties" action.
Seems that the "Reset Floating Menu / Item Properties" action is responsible for the crash.
Hi Andreas,
did you already had the chance to look into the action "Reset Floating Menu / Item properties"?
I have a workaround, but it is very complex to always do it with the action "Update Floating Menu ITEM properties", I guess that is why the action "Reset Floating Menu / Item properties" was introduced (!?)
I stumbled across another unexpected behavior with the action "Reset Floating Menu / Item properties": When I use it for a Floating Menu (not an item, like in the first post) it just does nothing.
My current UseCase:
  • I am working on a hierarchical action ring
  • when clicking on one of the items, it opens another action ring (and closes the first)
  • When I click into the middle of the second Action Ring, the first Action Ring should open at the previous position
  • I do this with the action "Update Floating Menu ITEM properties" and a offset in "Position on Screen"
  • Afterwards I want use the action "Reset Floating Menu / Item properties" to get rid of the X/Y offset
  • But this does not work
Do you have any hints on that one?
Bonus:
I found another UI-clitch in the action "Update floating menu properties":
  • The checkmark at "Use blurred background" cannot be unchecked (see video)
Thank you and have a great weekend.
Best regards,
Volker
Inspired by this thread (Floating menus background - #5 by Volker) I did some more research and found out that the misbehavior with the action "Reset Floating Menu / Item Properties" can only be reproduced if you use a "Circular Layout" with the option "Allow Hover on Whole Pizza slice" active. See video for details.
Thank you for the feedback, Volker. I have experimented around with pizza slices and, for now, chose not to use them. But when I do take a circular layout and enable those settings I get some very strange behavior. Also notice that when I close the menu then reopen it, everything seems fine.
Not yet, I'll check tomorrow!
No worries Andreas - you can take your time.
Meanwhile you can focus your investigation into the action "Reset Floating Menu / Item properties" in a
"Circular Layout" with the option "Allow Hover on Whole Pizza slice" activated.
I managed to solve this challenge with the actions "Save/Restore Mouse Position ".
I will share my Menu later this week with the community - just some final polishing.
Best regards,
Volker
