The issue occurs when the application loads. The app icon appears in the menu bar and the touch bar settings appear, then BTT crashes. I can pinpoint the issue to when I changed a return value in my "Run Applescript and show return value" widget which alters touch bar text via the option that the widget has to return json instead of a string value. I changed the "background_color" value to be returned to "255, 255, 255", whereas the default value (copied from the helper text under the return box), was "255, 85, 100, 255." (see screenshot) I was just messing around with changing values, but as soon as I hit save, BTT crashed and will not start again. To be clear, the crash is the result of the returned json getting three values for the "background_color" key instead of four.
TouchBar
- Type of Mac: 13" MacBook Pro 2016 with TouchBar
- macOS version: 10.14.1 (Mojave)
- BetterTouchTool version: 2.660
As of this time, I have tried turning off accessibility access for BTT, which does not solve the issue. Restarting the computer also does not help.
BetterTouchTool_2018-11-23-213932_Coopers-MacBook-Pro.crash (84.9 KB)
