BTT Auto-Launch Issue on macOS Sequoia 15.2
I’m experiencing a bug with BetterTouchTool and wanted to reach out for help.
I’m currently using a MacBook Pro M4 running macOS Sequoia 15.2 (24C101). The issue is that BTT keeps disappearing from the Login Items section. After restarting my MacBook, BTT doesn’t auto-launch as it should. I have to manually add it back to the Login Items every time, which is quite inconvenient.
I’m currently on the latest alpha version (5.083), but the problem still persists. Is there a way to fix this issue?
Thanks in advance for your support!
you need to enable launch on startup in the BetterTouchTool settings, the login items are not relevant.
