bTT as replacement for bartender or else
I tried out the menu bar feature today to replace Bartender or Ice. Now BTT has more or less messed everything up. The Ice icon disappears when I start BTT, and Bartender creates a second menu bar that spans the entire width of the screen.
I removed and deleted the presets, but something must still be stuck somewhere.
Is there a file I can delete to get things back to normal, other than completely uninstalling and reinstalling everything?
Ruben
Execute the "Show / Unhide All Menu Bar Status Icons / Items" action once, it will reset everything you might have configured in BTT related to menubar status items.
thanks that did the trick
