I'm trying to replace Geektool with the BTT Floating menu webview widgets and I have everything showing on my desktop just the way I want it with the exception of 1 major showstopper issue. Every time the widget refreshes, focus moves away from my current application. I'll be in the middle of writing and suddenly the focus is lost. Is there a way to refresh the widgets without losing focus from my current app ?
can you post an example script where you encounter this? (It's not normal behavior).
Which version of BTT are you currently on?
