The application froze and started using 100% CPU usage. I tried to force quit all BTT processes running from Activity Monitor. All processes except BetterTouchProcessPrioWatcher quit but BTT launched again immediately and once again froze before I could do anything. I tried quitting BetterTouchProcessPrioWatcher from the terminal using the sudo kill command but it relaunched immediately and BTT was still crashing. Also, occasionally the trackpad click stops working. This has only been an issue while BTT was not responding.
the prio watcher doesn't restart BTT it only affects already started instances, however the BTT watchdog called BTTRelaunch may do so.
To completely kill BTT, try these commands:
killall BetterTouchTool && killall BTTRelaunch
However it would be great to know why it is not responding. If possible it would be awesome if you'd sample the process when this happens again using this terminal command:
I'm having a version of this, where the relaunch tool is frozen, can't be force-quit. It seems to be happening when I put the laptop to sleep and wake it up. I've had to do a hard restart to resolve this in the past, though killing the BTTReLaunch process worked this time. However, trying to launch tthe app then returns a peculiar Finder error "The Application Better Touch Tool is not open any more".
I'm having a similar issue. BTT ramps up to 100% and all input is laggy. Here's a sample of when that's happening.Sample of BetterTouchTool.txt.zip (39.0 KB)
Hello Andreas, sorry for the late reply but here is the sample document you requested. I couldn't upload the original txt file so I just changed the extension, I hope this will not be a problem.
It would be great if you'd could post even more samples - the previous two give me a good idea about what's happening, but it's still very hard to identify the code that is leading to this.
thank you! I haven’t looked at the new samples yet, but I know that other users where having issues when using the sync, maybe try turning that off until there is a better solution.
