When I click at the end of a line of text in my screenplay, the whole area to the end of that line is selected, rather than the cursor appearing at that point, the expected behaviour. It takes a second click to get rid of the highlighting and just see the cursor inserted at that point. This behaviour vanishes when BTT is disabled.
iMac Pro
I did report to FD - which is the industry standard screenwriting software - but when I discovered that the problem went away when BTT is disabled, they referred me, not surprisingly, to the BTT developer.
It doesn’t happen every time. I'm a writer and am using FD all day every day. Every so often, when I use the trackpad with BTT enabled to click at the end of a line or block of text, (to add some more text), the area between the end of that text and the end of the line gets highlighted. And if I just start typing anyway, it does behave as if it has been highlighted - ie the new text I'm typing replaces the highlighted area - which causes chaos on the page because of the formatting rules in FD.
I have several rules set up in BTT - save, delete, forward delete - which are enormously helpful for my script work, so I have just been putting up with this anomaly. I thought you might have come across it before and just suggest a quick way to stop it happening.
Not sure. The issue I'm reporting is not when you click at the RHS of the page, by the edge of the page, but when you click just after the full-stop at the RH end of a line of text.
I have just tried to repeat your experience in one of my scripts, clicking at the edge of the page, and only got it to highlight once. I don't really do that in general so can't really say if it is expected behaviour. But what I'm reporting is something different and is definitely NOT expected.
It's hard to say because, in the video, you seem to just be floating over the area. In my version, I place the pointer at the end of a line of text, just after the full stop, and click. Then, instead of the insertion point appearing at that spot, (which is does most times), sometimes this highlighting occurs.
I don't think the highlighting floats down to the line below if I move the cursor, however.
Ah I'm also clicking in the video (just moving around the lines and clicking once when I reach the other line).
I'll try to report this to them - I also don't think this is expected behavior and on macOS Catalina it seems to happen pretty much always, even if all other apps are quit.
Is Catalina the beta of the new OS? If so, I don't have it installed yet.
The issue I've reported definitely seemed to stop when I suspended BTT, (not quit), but, because it's an intermittent fault, it's hard to be completely sure about that.
Good luck. As a developer, you may have more luck with them than I did.
Yep it's the beta, and I assume it makes the issue much more visible than before. (I guess that on your macOS version the event handling in BTT could lead to slightly changed event timing, and Final Draft somehow seems to be very dependent on the timing. On Catalina the timing seems to have changed regardless of BTT running or not.
So I think they will definitely want to fix this, otherwise all customers will experience the issue once Catalina is released (today the final Beta will arrive)
I've tried contacting you by email but you no longer seem to be replaying. I've got a problem with BTT and my Apple Magic Trackpad. Every so often, it doesn’t seem to recognise a click. I have to click several times for it to be recognised. At other times it works fine. I've switched BTT off and the problem goes away. I've studied the settings of BTT to see if I can work out what might be causing this but I can't find anything. Have you encountered this problem before? Could you suggest a way to fix it as I'd like to switch BTT back on. I find the shortcuts very useful.
