BetterTouchTool seems not to recognize apps created with Coherence X as separate apps in their own right.
Coherence X is one of thoes tools that creates apps out of webpages. It uses Chrome-based browsers, so in my case it's Chrome. I've been using it for Mastodon as the standard desktop apps aren't great, but I thought it would be nice to use for Google Calendar as well.
However, BTT just sees it as Chrome, as that's obviously what's actually running. Is there some way to recognize that it's been launched as "Google Calendar.app" (which is what the gestures are associated with) and somehow keep sending all commands to the window/s of that app rather than looking for Chrome?
you could create a conditional activation group, these can match based on executable path or process name
Thanks! That has worked!
