See subject line
On Sequoia, when I'm two folders deep (e.g., enter first level folder, then enter folder under that), search GUI gets all Picasso
Note:
- Type of Mac:
- macOS version:
Thanks for reporting, should be resolved in 5.242 (uploading)
Continued problems within this bug report's scenario - update:
Bug Report: UI Focus Loss & Navigation Glitches in Nested Group Triggers
Environment & System Info
BetterTouchTool Version: 6.737
macOS Version: macOS Tahoe 26.5.2
Hardware: MacBook Pro (14-inch, 2021), Apple M1 Pro, 32 GB RAM
Description of Issues
2nd-Level Sub-Triggers List Search Box Focus Loss:
Issue: When trying to type into the search bar within a nested/2nd-level trigger group, the input field drops focus after a single character is typed.
Behavior: Attempting to search immediately halts input after one keystroke, making it impossible to type full search queries into the sub-level search field regardless of click/selection method.
3rd-Level Sub-Triggers Selection & UI Instability:
Issue: Selecting or attempting to edit any trigger item within a deeper (3rd-level) nested list causes severe UI rendering and state-selection bugs.
Behavior: Clicking a trigger fails to keep it selected, unexpectedly clears out the selection, or jumps visually to an incorrect item/pane instead of opening the expected trigger details.
Steps to Reproduce
Open BetterTouchTool Settings and navigate to a trigger configuration tab with nested group triggers.
Open a 2nd-level nested group and attempt to type multiple characters into its search bar. (Observe: Input stops after 1 character).
Drill down into a 3rd-level nested trigger group.
Attempt to click or edit any trigger in this list. (Observe: Selection clears out, UI jumps unexpectedly, and action configuration pane fails to display correctly).
Expected Behavior
The search input field should retain focus and accept multi-character search queries across all nested group levels.
Triggers in 3rd-level sub-groups should remain selected when clicked and accurately display their corresponding configuration settings in the right-hand panel.
