When trying to import BST settings into BTT using the experimental button, does not work. It has worked in the past before upgrading to Big Sur.
Window Snapping
Video: Loom | Free Screen & Video Recording Software
- Type of Mac:MacBook Pro (15-inch, 2019)
- macOS version: 11.2.1 (20D74)
- BetterTouchTool version: 3.553 (1693)
I've tried:
- restarted laptop
- trying to import with bst open
- trying to import with bst closed
- import after reset of snap areas
- disabling/re-enabling snapping feature in BTT
- closing BST when BTT running
Thanks
