BTT 3.402 - Under Normal Mice Settings on the right tab bar, there is a button for "Problem with click recognition?" that leads to a non existent page: https://docs.folivora.ai/docs/normal_mice_problems.html
Having the same issue. This bug is easy to fix! Just replace the broken link (unless there is no such page and it has to be constructed from scratch)! It should not have taken over a month since notification to address!
