- Yes, it is up to date
- I tap on the brightness icons on either ends but the slider won't move, it just stays in the middle. And if I drag it to anywhere else, then tap on either the icons, the slider always moves back to the middle bar.
- Touch Bar
- Type of Mac: MacBook Pro 13-inch M1
- macOS version: Monterey
- BetterTouchTool version: 3.653
