With BTT 6.017 on a MacBook Pro M4 Max with macOS Sequoia 15.7.3
Blocking X AXIS now appears to block both X and Y axes where, previously, it worked as expected.
I tested using the .bttpreset from another topic, which I’m including here for convenience.
Any pointers appreciated. Thank you.
x.bttpreset (3.1 KB)
It seems to work fine here (there hasn't been a change to this since the preset was posted). However this behavior can happen if used on BTT itself (e.g. on BTT's preferences window) - because BTT can not easily modify the events sent to itself. Is that maybe what you are experiencing?
Andreas, thank you so much for your quick reply!
That was exactly the issue: I was testing/debugging in BTT. Being new to BTT, I recall this behavior when first setting up.
Thank you for the gentle reminder.
