BetterTouchTool stops working randomly
Everything works as expected but after a while, while doing some work, gestures stop working, having to do them multiple times until they go back up, after that everything works as expected again, I have installed process priority helper tool but it still happens, anyone having this problem? Im using a magic mouse.
Note:
  • Type of Mac:
  • macOS version:
  • BetterTouchTool version: (please post the exact version - not just "the latest one")
what kind of gestures & actions are you using?
mac m1 pro. 14.6.1
It automatically quits after about one minute.
I only added a few mouse gestures.
I’ve tried several versions, including the latest one, and they all behave the same.
I’ve also restarted the computer.
Just checking, because "quits after about one minute" sounds like a blacklisting issue. Did you always have versions from my official website installed? (if you had used pirated versions before your machine might have gotten blacklisted)
For example for the magic mouse, tap to click, 3 finger tap to delete, those constantly stop working after a while and I have to do them a couple of times to make them work, after that, everything works perfectly until it randomly happens again
strange, could you go to help -> export diagnostic debug information and send the result to me? ( andreas@folivora.ai)
I have never encountered tap to click stop working :-/
Previously, I used someone else's certificate for a period of time. Now I'm using a certificate that I purchased myself. How can I check if my computer is on a blacklist, and what should I do to get it removed from the blacklist?
Sent my friend :+1:
