Every now and then (not sure if it is time based or maybe after some particular actions) the shown results are not in the order I've configured - results from "Bookmarks" to be at the top, everything else below them.
Here you can see that I have the "Bookmarks" item with the highest number, but all of the shown results, on the screenshot, (unfortunately I have not check if my expected result from "Bookmarks" is even in the results) are from the "Browser Tabs":
But here's another example - latest result is from my "Bookmarks" item and all previous results are coming from "Browser tabs":
One of the results above is https://github.com/stacklok/toolhive-studio, with tab name "stacklok/toolhive-studio: ToolHive is an application that allows you to install, manage and run MCP servers and connect them to Al agents", so not sure why this is even matched when I type "cloud admin". The other results (they might contain some sensitive info so I cannot provide them) I also think should not be matched/shown.
After a BTT restart it starts working normally and as you can see no results from "Browser tabs" are in the list at all :
BTT: 6.671
macOS: 26.5.2 25F84
