This buggy behavior persists in BetterTouchTool since as long as I can think.
When BTT is freshly started (starting with MacOS here normally) Magic Mouse behavior is perfectly normal.
Horizontal scrolling in Mac OS works as intended (for example to dismiss notifications, navigate on webpages, in Finder Windows, etc …).
After a while though Magic Mouse scrolling behavior (and as far as I can see this EXCLUSIVELY is related to horizontal scrolling) deteriorates and stops working entirely.
You have to restart BTT from the BTT Advanced Settings tab and immediately horizontal scrolling works again as intended. … until it deteriorates again.
This behavior has been with BTT over many Mac OS versions, several different MacBook Pros over the years with many different Magic Mice over all generations of them.
I am not using (as far as I am aware) any BTT magic mouse gestures.
I only use BTT for the keyboard shortcuts and windows management features.
Magic Mouse
- Type of Mac: Mac Book Pro 2018
- macOS version: Ventura 13.1 (22C65)
- BetterTouchTool version: Version 3.952 (2117)
