TLDR version: With BetterTouchTool running, it will cause Eclipse to hang when using the UMLet plugin. More detail can be found here: https://github.com/umlet/umlet/issues/399#issuecomment-416262489
What we're not sure yet about is if BetterTouchTool has a problem with UMLet, or one of the packages it uses. We're leaning towards the latter. (I'm working with that dev checking older versions that use different packages.)
What we can say for sure 100% however is if BetterTouchTool is not running, or it is running but with an app-specific configuration to ignore Eclipse completely, everything works as expected. (Note: I did not test the finer-grained configuration options, however I also didn't see any that seem like they would fit.)
macOS (all machines)
- Type of Mac: MacBook Pro
- macOS version: 10.12.6 (but other versions too)
- BetterTouchTool version: 2.605(909)
I have something, but it's thousands of lines long. If I can find a way to attach a file here, I will.
