BetterTouch tool is current disabled after waking up
Hello,
I have been a long time user and lately every time that my Mac mini wakes up I have the message on the panel saying is was disabled.
I was trying to recreate the problem putting my Mac to sleep and open it right away, and everything works, so I think the problem starts when I have to use the Touch ID to access/wake the Mac
I have enabled (Restart BTT after wake from sleep).
I am using BetterTouch for a Magic Mouse and window snapping.
  • Mac mini, M4 using OS: 15.1 (24B2082)
  • BetterTouchTool version: 4.879
Please let know if you want me to send you something else.
Thank you
Note:
  • Type of Mac:
  • macOS version:
  • BetterTouchTool version: (please post the exact version - not just "the latest one")
usually this happens if the experimental dropbox or icloud sync is used and some bad state is synced. I'd recommend to disable that sync if you are using it.
Hi Andreas,
Thank you for your quick answer..
I don't think I have that settings activated please check link Screenshot 2024-11-18 at 10...
Hi Andreas,
Since I update the app, is now working as expected, I guess I didn't have the right version before, I can't recreate the problem anymore.
Thank you for your amazing product.
