BetterSnapTool - Manual Resize Causes Snapping
Using BetterSnapTool, when resizing a window (by dragging from an edge or corner), screen-snapping activates if you drag to any edge of the screen, same as if you were dragging/moving the window.
I'm not sure if this is an intended feature, but it's never my intention to snap a window size in any way when I'm manually resizing the window with my mouse. And even though I've chosen "Integrate With Native System Resizing," this is not a behavior of native snapping features.
I don't see a way to disable this behavior – am I missing it?
Affected input device (e.g. MacBook Trackpad, Magic Mouse/Trackpad, Touch Bar, etc.)
LogiTech MX Master 3S for Mac
  • Type of Mac: Mac Studio
  • macOS version: Tahoe 26.5
  • BetterSnapTool version: BetterSnapTool 1.9.12
