I'm tying to export the BetterSnapTool settings from a Studio M3 to a MacBookPro with extra monitor. All latest updates. Both setups use a 4K native monitor set to 3200x1800. The MBP has the external monitor set as main monitor in mirror mode.
On the BetterSnapTool Github pages, it says "Backup your BetterSnapTool settings via export feature.", but I couldn't find it. Tried copying the user/library/preferences/com.hegenberg.BetterSnapTool.plist and ~/library/application support/storedata files, but that didn't work.
There is also a 'Get BeterSnapTool Setup Assistant' linked button on the github page, but the link is dead.
I tried mailing to the support@bettersnaptool.com mailaddress mentioned on Github but that mail 'could not be delivered'.
Is there a way to copy settings to a new computer?
Cheers,
Leon
