So I have created a bash script that makes a curl command, parses the response, and copies that response to my clipboard. I have tested this script in terminal, as well as in BTT's script editor by clicking "Run Script Now". It works perfectly. But after assigning the script to a button on the touch bar, the button does not do anything, the script is not being executed.
MacBook Touch Bar
- Type of Mac: Mojave
- macOS version: 10.14.3
- BetterTouchTool version: 2.854
