Steps to reproduce:
Running AppleScript uncompiled
- Create a new action as
Run Apple Script (blocking)andSource type: Applescript,
for example with this script pasted directly in the BTT script window:
set appName to "Finder"
set startIt to false
if not (exists process appName) then
set startIt to true
else if frontmost of process appName then
set visible of process appName to false
else
set frontmost of process appName to true
end if
end tell
if startIt then
tell application appName to activate
end if
Use a timer and benchmark how fast it runs to completion.
Running AppleScript compiled, code-signed and written to disk
Open the same script in Apples Script Editor.app
Export>>File Format: Script(.scpt) with options:-
Code Sign(use your Apple Development profile) run-only
- Save somewhere as your_script.scpt
Reconfigure your trigger to Run Apple Script (blocking) but with `Source Type: Apple Script From SCPT file"
Benchmark again. No surprise it runs so must faster, but also starts so much faster. No lag.
A: a possibility for BTT to automate this? (compile, code-sign, save, re-import to BTT action)
or
B: any way for me the end user to automate this somehow?
Keep up the great work!
BTT works great on Catalina now with the recent builds.
