It's a little hard to describe, but it appears that the icons detecting whether itunes is playing/ detecting the audio level are crashing after my computer has been sleeping. This is a recent issue (most recent update), and I'm not sure what is causing it. See screenshots.
Touch bar
Crash:
What it should look like:
- Type of Mac: MacBook Pro 15" 2017
- macOS version: 10.14.2
- BetterTouchTool version: 2.687
