Inside a "Cycle Through Multiple Action on Repeated Trigger" I am trying to create a "Repeat / For Loop" that has delays.
The loop works fine as long as I am using "Blocking Delays", but that makes BTT hang for some reason (even though the delays are only 20 seconds and the loop is simple). Sometimes I need to force restart BTT.
If I use "Blocking Async", the loop runs only once (i.e., it doesn't loop). It won't even continue actions supposed to happen after the loop ends, it simply stops everything altogether. BTT continues to function normally though.
N/A. Trigger is configured under "Keyboard" section and is started via UUID.
- Type of Mac: Macbook Pro 2021 16" M1 Max
- macOS version: PWWXXRR9VN
- BetterTouchTool version: 4.333
