Assign value to selected_text variable, and locate it again later / paste over
First off, thanks so much for developing BTT. Ill be buying soon, it's so helpful.
I'm attempting to create a macro which
-Assigns copied (or currently highlighted?) numbers to var selected_text within BTT (project code #s)
-Switches tab
-Copies other text from another window(fully formatted project code info)
-Returns to initial window, locates var selected_text
-Pastes
I've gotten most of the way, but I'm having trouble working out assigning and finding selected_text on screen. Any guidance is greatly appreciated.
Thanks again! Have a great day.
~Peat
maybe this helps: How to use variable in "Find/Search Text on Screen & Move Mouse"?
Best select the „search in focused window option“ to prevent false matches
Thank you kindly, I will review and reattempt.
