Hello everyone!
Just purchased recently the app. Actually everything works cool except Apple Scripts. I created a script, checked it separately - it works OK. Then i try to attach it to the hotkey. And... it attaches, but doesnt run. Not only when i click hotkey, but even when i try to run inside BTT, while i attach it to hotkey. I tried to launch it as external file, as a text - nothing works. Looks, like BTT just ignore it. The hotkey works, because i add HUD message after script laucnh and i see this message on the screen... All permissions BTT asked me to give him, i gave. What shold i check? Thanx!
Note:
- Type of Mac:
- macOS version:
