Descrption
I have BTT and Bartender 5 running.
If BTT is active Bartender menu seem to be broken (very wide with elements on the left and some small lighter area is visible when mouse is over the bar).
If BTT is not running, Bartender's bar looks good.
I had previously activated sequoia_status_item_bar2 preset but now it is removed and default preset is set (with one floating menu only).
** Screenshots **
- Type of Mac: MacBook Air M1 2020
- macOS version: Sequoia 15.3.2
- BetterTouchTool version: 5.271
