This is somewhere between an “unexpected behavior” report and a feature request...
The key sequence setting “Max pause between keystrokes” can be set between 0 and 2 seconds. This causes two issues:
- 2 seconds is too short for some uses, making sequence recognition fail.
- 0 seconds necessarily causes recognition to fail because it is impossible to sequentially type with a 0-second pause.
1 is an issue for me with text replacements. I often pause typing for longer than 2 seconds before completing a sequence. For example, I use sequences like 1//2 as shortcuts to type fractions in the ¹⁄₂ format, but that sometimes fails because, having already typed x//, I’m still pondering the last digit to type.
So my suggestion would be to allow longer max values, and to not allow 0 seconds. Alternatively, 0 seconds could act as “disabled”, i.e. any pause would be allowed. If technical reasons preclude arbitrary pause lengths, 5 seconds would already go a long way to reduce failed recognitions, I think.
- Type of Mac: 2024 MBP M4 Pro
- macOS version: 15.6.1
- BetterTouchTool version: 5.649
