Alert sound for BTT shortcuts
Hello, is there any way to configure a BTT action to produce an alert/system sound when successfully performing an action?
you can use the run terminal command action like this:
/usr/bin/afplay /System/Library/Sounds/Glass.aiff
The available sounds are
/System/Library/Sounds/Blow.aiff
/System/Library/Sounds/Basso.aiff
/System/Library/Sounds/Bottle.aiff
/System/Library/Sounds/Frog.aiff
/System/Library/Sounds/Funk.aiff
/System/Library/Sounds/Hero.aiff
/System/Library/Sounds/Morse.aiff
/System/Library/Sounds/Ping.aiff
/System/Library/Sounds/Pop.aiff
/System/Library/Sounds/Purr.aiff
/System/Library/Sounds/Sosumi.aiff
/System/Library/Sounds/Submarine.aiff
/System/Library/Sounds/Tink.aiff
