Jelski
April 19, 2020, 5:56pm
1
Hi All,
For a while now the blue colored AirPod icon doesn't show up when they connect to my Macbook.
(However, the volume up icon shows up blue like supposed to)
The white icon shows when not connected.
I'm running version 3.362 (1578)
Hope you guys can help
Thanks
MT3CH
April 20, 2020, 12:29pm
2
You have to download latest Beta of GoldenChaos here:
Golden Chaos Beta
This type of issue is fixed, here's mine with a little customization
Jelski
April 20, 2020, 1:43pm
3
Thanks for your answer.
Downloaded the Beta, now my customization is messed up, so i'll run with it untill it gets fixed in a offical update.
